Deck height adjustment
1907 Views 4 Replies 4 Participants Last post by  mbrun
Just took delivery of a new to me 2007, 720 w/54" deck. I was playing with the height adjustment knob to get to the setting that I used when I borrowed my neighbors mower. The knob is very hard to turn, I had the deck all the way in the up position. On my neighbors it turned with a lot less effort = 36 or 48" deck. Would the lighter deck make a difference in the amount of effort it takes to turn the knob, if not what should I be looking for or do to remedy this situation?
Thanks
Dan
Get under it and lube it with wd40 or some similar lube and work it back and forth.
Inspect the threads for dings and the shaft to see if it's bent.
Try it with the deck not quite all the way up. mid way, and not quite all the way down to see if it's binding only in a certain location.
This is normal on many of the new tractors. The knob hasn't been broken in enough to turn easier. It gets better!
Thanks guy's I got it freed up, had to take the deck offl Kept working it and squiting it.
Dan
Dan
Glad you got it fixed. I had the darnedest time turning the knob on the x500 the first couple dozen or more times I used it. Eventually it loosened up and now it is a piece of cake to turn.
