I have a 1995 toro 12 32 rear engine rider,it did not have a deck belt when I bought it.I have the correct belt that drives the transaxle it 1\2" wide and matches the width of the pulley.the only info I have found calls for a 58"x1\2" deck belt. the pulley width looks like it would use a 5\8 wide belt ( the pulleys are original) any help appreciated Mel
Do you have the model and serial number? There are 6 different models of 12-32 for 1995 and the model number will look like 70120. The serial could have 7 or 8 digits and should be on a decal on the rear fender pan under the seat.
Garry
mod #70120 serial#5900713,I have spent over an hour working these numbers with conflicting belt #`s.the local dealer said part # was 92 0895 this belt is too long.I have found these #`s 920870 471420 980710 671390 but they do not give the size.any help will be greatly appreciated Mel
the 920875 1\2 x 58 is the belt the dealer sold me, this belt is too long.after hours of digging in the comput. I came to another toro site and with this mod.# and serial # it give the belt to be 1\2x51. I drove 15 miles to tractor supply and empty slot where this belt was listed. I just stoped by the liquor store on way home, I`ll try again later. thanks for the reply Mel
