1 - 3 of 3 Posts
would it be possible to rebuild deck bearings.if you could buy the ball bearings.at a 100 dollars for six thats a little bit much.:thSick:
I wouldn't try it... If the bearings are that worn out then the races could also be shot too.
If you already have your deck bearings out. Try stopping by an Autoparts store to see if they can get the deck bearings cheaper for you. Any local bearing supplier might be another cheaper option too.
I just picked up a set of six a couple months ago for around 56 bucks. They were the standard sized bearings that most decks use. Purchased them from a local bearing service dealer.
1 - 3 of 3 Posts
