In my experience with plugs,Champions seem to foul easier and refuse to work once they do--I have seen many develop pinholes in the center electrode and the spark jumps there,instead of the gap,and they wont fire an engine when under compression when they get like that...flood one once by over-choking it and you'll never get it to fire up an engine again,despite it having a nice healthy blue spark at the gap,it "blows out" under compression..thats why those old time spark plug cleaners had a pressurized chamber you could watch the plug sparking thru a mica window,and often youd see the spark dissapear when you applied the air pressure..
Plugs I wont buy are any "miracle" plugs with forked or multiple ground electrodes,etc,that cost 5+ bucks each...and Bosch Platinum spark plugs,they suck--I have seen several instances with them when an engine is tuned up with them,and they skip or run worse with the new plugs than the old ones did!..they are "dead" right out of the box...this is especially evident in older GM V8's..I'm not a big fan of NGK's either (No Good Crap),I developed a hatred for them back when I was a teen with a C110 Honda,no other plugs would make that 50 cc engine run but an NGK,and you'd get about 4 hours out of each one,then ,like they had a timer in them,they would expire ,and you weren't getting that engine to run again till you blew another 10 bucks on another NGK--they were 10mm plugs and few parts stores carried them...I had good luck with OLD Bosch plugs in my air cooled VW's though...I liked using Autolites in my Chevy's, # 26 or #145's ran the best and rarely fouled or gave grief--same with the ols AC "fire ring" spark plugs,seems you could flood them bad and after you let them dry out,after the engine started they would self clean..not so with a Champion,once fouled the engine wouldn't even pop with starting fluid..
Many engines on mowers I got from the dump started right up after I ditched the Champion plug and put in an Autolite,and fresh gas...the newer plugs without any ribs on the insulators seem to allow "flashover" from the boot to ground when damp too...Idont like them either...only "miracle" plug I ever bought that worked and lived up to its claim of "fires in oil" was an "Aldor" brand one,those simply wont foul!..but they cost 5+ bucks each and though they will let you run a engine that burns oil bad,they are probably a higher heat range,which could lead to engine damage in some cases..
Bottom line is in a one cylinder engine,you have just ONE spark plug,and its got to be a good one,if you expect it to run!...
