1 - 11 of 11 Posts
· New ride, same concept
Well going to keep this easy.... Picture below..... How do you make this happen? I can get one side off bit not the other.
I've already jabbered the top pulley, ordering another. But I still can't disassemble. Any ideas? Coil spring Suspension
· Tractor Nerd
When I had issues with one. I stuck it in a chest freezer for 24 hours. Two hits with a hammer and it fell apart. My other plan was to put it in the shop press.
Freezer trick worked
I also upped the hammer I was using. I risked the chance of breaking something. HOUSEHOLD6 said the deutz ( **** thing - her words ) would cut grass this year or be gone before Christmas.
Needless to say tools went flying and I mowed the yard with it
One other method I found on the web was to apply the heat to one side of the pulley and on the other side rub the was from a candle. As the wax melts it wicks down around the shaft as it moves towards the heat and will lubricate it making it easier to remove.
I have only had to do this once as heat followed by quenching has always worked for me in the past but I had a pulley on a hydro pump that would not come off for anything until I used the candle method.
Yup I keep a bit of bees wax around to remove stubborn stuff.
:sidelaugh Helps I have the wax makers on the property too.
We have been thinking of setting up a hive or two.
Have you seen the new hives with the automatic drains for the honey?
Kind of pricey but very nice and a lot less work.
I was ready to cut the pulley right off the shaft when I read about the wax trick. It worked but I did have to do a lot of hammering. I did not want to put on too much heat and destroy the o-rings and oil seals in the hydrop pump.
· Keeper of the bees-Now deceased
Old saying, fools and their money soon part.
If you don't want to do any work just find a bee keeper and have them place hives on your property and take rent in honey.
I would not take a whole box car load of those hives for free, and neither would most experienced bee keepers.
1 - 11 of 11 Posts
