Ok.. so im working on a D400 iron horse engine at the moment. It had a rather scored piston in it along with stuck rings. Its a 606607 piston (the 2 ring version). Ive tried and tried to find a new piston but they seem to be a little difficult to get here in New Zealand now. Ive got several other D500's which ive stripped and have found stuffed pistons in as well, so id like to replace them all if i could.
Does any one know if the F series piston can be modified to work? From the information ive found the only differences between the D and F pistons are a thicker top ring on the F series and a slightly larger diameter (~ 18 thou bigger). Any reason i can't have one machined down to fit? Or even bore the cylinder out instead? That said.. the cylinder diameters between D and F series appear to be the same size, 2.380 - 2.3810. The compression ratios are also different between the D and F series but im assuming thats to do with the head more so than the piston?
