seems high
look around at three different tractors before you buy,
alway good advice in purchase of car, truck or most anything.
d-14's had a problem with trans, when going down hill they would jump out of thrid gear, as the gears got worn, all i ever saw did it,
so for safety reasons, you need to work it on flat ground or be sure you have good brakes.
can be a real safety issue if you plan on having kids drive the tractor on hills.
test: have the tractor in 3rd gear and start off down a hill, take foot off the brake and let the trans/motor hold the tractor back, that is when the trans pop's out of 3rd gear and off you go free wheeling. Weeeeeeee!!!!!
do not think the D-17 trans had this problem, the D-17 was one of the best power to weight tractors ever made.
remember these tractors are old and can have many repair issues.
also the lift systems will not work when you push the (foot clutch) in to change gears,
changing gears from foward to reverse is a issue with PTO running, pto had to almost stop before you can change gears.
you will love this feature when bushogging, in a tight spot, (ha,ha).
try a little fergy or ford before you buy
again always good advise to test drive 3+ before you buy.
however, i did like my old D-14 was a great old tractor just had a few old schoold draw backs.
