Hello all, first post on this site.
Idea/Goal:
My goal is to create a vehicle to pull our 9000 Lb pulling tractor around the pits. This vehicle would be almost identical to the larger tractor just scaled down (have the same tins, roll cage, paint, etc). My first thought was to build one from scratch, but then I remembered we had an old cub cadet sitting out back. Went and checked it out briefly today, It is a 72 model tractor.
Problem/s:
The cub is far from being in a running/driving condition. Beyond that I doubt a 7 HP engine is going to pull 9000 Lbs anyways.
Questions/Concerns:
How much horsepower do you think will be required to pull the larger tractor?
How large of an engine will the transmission/rearend hold up to? I work at a lawnmower mfg facility and I can get my hands on engines from 20HP up to 37 or 38 HP Big Blocks (I've read of frame cracking issues on the 70-100 models so I plan to beef up the frame section.
The problem with the engines I can get is they are all vertical shafts, I was thinking about running a 90 degree angle gearbox and then a driveshaft to the transmission. I haven't really looked at the driveline of the cub cadet yet to see if this is feasible.
Hope I don't upset to many people with the idea of chopping/welding/retrofitting/painting an old cub. In my defense it will be modeled after an IH 806 built in 67 or 68, so at least there the same age from the same family.
Any suggestions/hints/tips/honest criticism is appreciated.
Thanks,
