Thanks for all the help guys. I have one more question. On some of the pictures I can see the the bolts have nuts to hold bracket for glass. Does the frame have threaded holes for the rest? or are they self tapping screws. This is something I really want to do, going to call Dealer Monday.
Does anybody have Part# for these hard panels, the brackets and hardware.
I figured it would be easier to give part #'s to the dealer than explain. thanks
I just took the caliper out and measured them, and what you have is 1/4'' grade 8 bolts, nuts and washers holding the door hinges to the cab. I noticed the washers are a tad thicker it seems then a regular washer, but not a lot, I guess they are just not thin washers.
The window panels are held on to the cab with a clip and one metal screw in each tab which seems kind of flimsy but I guess if they are put in right thats all that counts.
I know when you shut the door the cab feels really solid, and to say I like this cab is an understatement, I flat out love it.
I just went out and took another look at those screws that are in the tabs holding the windows in, they have a lock nut on the inside, so what I thought was a screw is a bolt of sorts.
Rob
