????'s are why we are here. When you put the top back on just get the gasket lined up and all will be fine. DO NOT use any sealer on the gasket for the cover or hydraulic pump, put them on dry.
The spring is not really under any tension to speak of and you can remove it without worry. Just be careful NOT to try to turn the end of the shaft or you will break the attachment point under the cover. Generally taking the shaft that go though the spring apart requires a LOT of work and penetrating oil.
