1 - 3 of 3 Posts
I am looking to make a cheap good looking and simple cultivator for my garden tractor. 5ft would be the max and 3Ft would be the least. Just wondering if you guys had any good ideas. dont really know where to start.
Thanks
I took an old burn-rack out of my fireplace, turned it upside down and zip-tied a couple cinder blocks and a 2x4 on top of it. Then I drilled a hole through the 2x4 and zip-tied it to the back of my tractor hitch plate. Worked great. It only dug down an inch or so, I was preparing some dirt for grass seed.
That is the type of tool you can spend as little or as much as you want, or maybe depending on its intended purpose or what tools you have or what you want to spend someone would give a better recommendation.
1 - 3 of 3 Posts
