I have a cub cadet 3205 with steering problems. It will not turn to right very well. Turning left is ok. I have had 3 different used steering control valves and all 3 does the same thing. My question is this: can the lower steering cylinder leaking internal cause this problem? I would think it would. I would think it would be the same both directions but maybe not. Thanks
I am not familiar with your model to be sure but a cylinder is weaker in one direction than the other due to the displacement of the rod. Maybe a pressure issue?
See blind end versus rod end.
While it is remotely possible for a cylinder piston seal to be worn in such a manner as to cause steering issues in one direction and not the other, I'd be more inclined to suspect a hose issue. Hoses have been known to fail internally and form a sort of check valve restricting flow in one direction and free flow in the opposite.
This based on the installation of 3 different ps valves with the same results.
Also, while trying to go straight, the front wheels will slowly turn to the left so you have to keep constantly turn the steering wheel to the right all the time so you can go straight. It does build your arms up doing this. Lol.
Related Threads
My Tractor Forum
4.3M posts
216.7K members
Since 2005
