I have a 2008 cub cadet lt 1045 with a Kohler Courage 20 engine.
It has never given me any problems at all, however I was changing the oil and oil filter yesterday and after changing the filter/oil I have noticed something very strange. Upon starting the engine, it will rev full throttle for about two seconds before returning to proper idle. My dad also mentioned that it is "3 times faster" than it used to be and that while the pto (mower) was engaged, the throttle would rise and bog randomly every so often.
The only thing I can think of is that when removing the filter with a filter wrench (it was on very tight) it was pushing up rather firmly on the stainless steel plate that hides the throttle/choke cable mechanism (could something have bent to cause this?). I have checked the throttle cable and choke cable operation/alignment and it all appears normal. I am completely baffled as to what it could be. Any ideas? Before the oil filter change it would start with no rev and ran completely fine with no bog or rev.
