Hi,i have a creeper gear question.Last summer i got a high/low (creeper gear) for my 102 but a mouth ago (or less) i sold it.And i bought a cub cadet 100.I have 2 questions,1:Would a high/low for a 102 fit a 100?2:In the stock clutch there is a two holes in the driveshaft,the one on the end of the driveshaft goes in the cupling (that's on the front of the rear end and trany).But then there's another hole in the driveshaft that's closer to the clutch spring (distance between both holes is about 5 inches). Now is that hole closer to the clutch spring for if you wanted to put a high/low in it?That's what I'm thinking but i want to make sure?
Would appreciate your help
Thanks
· Farm Show
Yes, I believe a IH Cub Cadet model 102 creeper would fit nicely in your IH Cub Cadet model 100. You will need to cut the driveshaft. Look hard at my picture and you can see the line you cut on. And you can just make out the hole before the cut.
Do you have a install manual? I dont, but know you need the correct length creeper mounting bolts. Alway use new coil pins too. Hope this helps!:tee:
The reason i asked if a high/low from a 102 would fit a 100 was because the slot where the lever (on the high/low to change it from high to low or low to high range) goes in,is a bigger slut then on the 100?
