Does anyone know if a Cub Cadet 633 backhoe attachment will work on a Cub Cadet 7264 SCUT? I know the 612 is the correct backhoe attachment, but I have the opportunity to pick up a never installed 633 for decent money. I’m worried it’s too big. There’s no subframe mount, but I can probably have one made up. Thanks!!
A Cub Cadet 612 backhoe was the unit designed for that machine. While both units were deployed on 7000 series tractors they don't share a common subframe mounting system. That said, you can make your own or buy the subframe and alter it for your tractor but it'll take some fine crafted handy work for sure. You may find the fitment isn't perfect as well. Good luck.
Sent from my Pixel 3 XL using Tapatalk
Thanks for the info!! I have to find a stabilizer arm cylinder that will work for the outrigger. The 917-3236 part seems to be near impossible to find.
