1 - 1 of 1 Posts
Working on a friends 5252E. Said the entire instrument panel was deadand the PTO was not working. Read on a few other forums that the electronic instrument panels had melted and were the cause. Same case here. Pulled it out and the back under the RPM side was completely warped from heat. Because the 5252E has an electronic dash the components are not replaceable like they are on the 5252.
My question is do any of you think this melting warping was from the exhaust heat or the failure of the instrument panel itself?
As is usual with these tractors the header pipes into the muffler were broken and had been for some time. That has been welded and fixed.
1 - 1 of 1 Posts
