I found a "mobile" tractor service guy in the area who came out to see if he could solve my problem. First thing he did with the tractor cold was check compression and all was well. He then took both side shrouds off and told me to have at it with cutting the grass to get it to shut down on me.
The tech felt the fuel filter and thought it was hotter than he usually sees and believes that by having the shrouds off enough additional cooling was taking place that my problem was solved.
He felt that with everything buttoned up when the unit got hot enough a vapor lock was created in the fuel system that goes away once cooled down.
I think the engineers at these GT companies are off the beam big time. They have done everything possible to trap heat inside a plastic box with great success.
Take a look at real farm tractor design past and present.
-Hoods made of metal, not plastic
-open sides to let the heat out
-mufflers outside the heat box.
Take a look at current GT design
-Plastic hoods
-enclosed sides
-mufflers inside the heat box
-extra heat shields to block heat dispersion and not melt the plastic hood. Resulting in hot, hot engines and PTO's.
I think the best thing you could do for one of these new GT's is to rip the plastic hood off, pull off the heat shields, redo the exhast and get the muffler outside the engineered plastic heat box. Have a new sheet metal hood with no sides fabricated at a local shop. While you are at it have a metal oil valve installed to replace the plastic valve they seem to love even though it's not functional for oil changes.
But what do I know. Someone will tell me I would be voiding the warrenty by changing the design operating temp of this or that. Never could figure out how it was Ok for the GT Co's to just add/retrofit their designs by adding /modifying the heat shields to existing engines (trapping more heat to stop the hood from melting) but if you did something to reduce the extreem heat you would be voiding the warrenty. Could it be that these new designs are to insure the machine will be dead in 5-6 years and they can sell you a new one, kinda sad to be thinking that way.
Am I nuts or would you think a cool engine and PTO would outlast cooked ones. Is there no room for common sense in today's world.
