My 1782 is sort of fine except the transmission won't go much into forward and very very little into reverse.
The problem is simple. The plate that goes around the double spring & endcaps has become sloppy loose and the endcaps and center spring have fallen out and the big spring left has 1/4" of slop both ways until it moves the transmission valve.
That bolt that holds the plate is impossible to get to without either drilling a big hole in the frame so my torx (or hex) socket can be used or remove the transmission to replace the plate thats loose and the springs with the ones off my very low hour 1864 transmission. I THINK the transmission in the diesel also might have the running away problem. Even though it would barely move into forward, it would move about 12 ft then suddenly take off.
Either way, the transmission in the 1864 frame looks like a straight bolt in, even though I was told they won't swap.
I'm aware the 1782 super has different gearing. I Imagine its slightly lower to offset the slightly taller tires. I think it wouldn't be so much it would be noticable, and I have my gas Super to compare with.
I really don't think I can sell the 1864 trans for anything worthwhile because of the shipping, so I'm planning on swapping it in since I really have to remove them both anyway and see why it will or won't work.
