1 - 3 of 3 Posts
My 1715 keeps blowing the yellow 20 amp fuse under the seat next to the battery.
Any idea what could be causing this?
This was happening last fall.
I never figured out the cause and since it was the last cut of the year, I just parked it because I didn't have time to work on it.
I'm not sure what I was doing when it blows (twice happened) but I think it blew when I used the brakes.
The little brake pad it uses is completely shot and need to be replaced.
Is there some sort of switch or something operated by the brake pedal that could blow a fuse?
Any ideas of how to troubleshoot this would be appreciated.
I have no wiring diagram.
Your owners manual should have the electrical diagram. If you don't have it, you can get it here:
An electrical multimeter is needed to test the circuits to find where your short to ground is coming from. Sometimes it is quite obvious and others, not.
1 - 3 of 3 Posts
