I am rebuilding the lower end of my transaxle. While I have it apart, I am changing the fluid and filter in the hydro pump. I contacted cub cadet support and ask about the fluid. Here is their answer. (Normally replacing fluid is not necessary unless the drive system is damaged, leaking or in need of other internal service. Hydro-Gear® factory uses 10W-40 motor oil during assembly, but also approves the use of 20W50 oil when servicing the hydrostatic system and this oil needs to be replaced.)
Would you recommend a synthetic oil and if so what? Thanks for your help.
w
w
