HELP. ok i just rewired my 127 with new porch harness, hooked it all up. There is a "short" or something going on. Ok, when I hook the Gray wire up to the VR, (the one that goes to the dash gague, the VR starts Humming loud. I just also figured out that the Coil is bad, but would that cause this? Is the VR bad? I also have new points and condenser installed, Please Help !!!
I have all the diagrams and its hooked up correct, want to know what item could be bad causing the "short" and or why the VR is humming. Thanks
Double check the wiring just to be sure. Perhaps one of the connections that has power is grounding against something and creating that short.
