38 said:Get the lmt number from the walbro and look for one.try ebay for it.
I don't understand. I have a Nikki, he has a Nikki, and his parts list does not specify a walbro replacement. Where to look? What is 'lmt'?
I have a Walbro on a Kohler 14, a Nikki on a Kohler 15. I have not looked at the linkage, but it seems the Nikki has two throttle plates. The one set by the hand throttle linkage, and one a bit closer to the engine that is operated by the governor link. I did not look closely, as I just wanted the dang thing to run. It had sat for X years, complete with mouse nest under the shroud. Carb was gunked. I thought I saw an O-ring seat fly out when I blew air through the passages, looked for the seat, empty spot. Spent 4 hours cleaning the garage and found nada. Came to find there was no rubber seat, viton(?) was on the tip of the needle. The blowup picture of carb in every parts list showed separate needle AND seat. Totally unavailable in every parts list I could find. E.g, item 5&6 would be skipped in the parts list when they were the needle & seat in the pic. So I figured there was a seat missing, and had to find a kit.
Any way, I'd look for a similar engine in a yard, complete with Walbro, or just bite the bullet and buy a kit for the Nikki. I have noticed that the Nikki, cutting 42", uses a LOT less fuel than the Kohler 14 on a 33" snapper. But, it is persnickety about there being any water in the fuel, and causes the engine to have intermittent misses. The Walbro on the Kohler will happily eat fuel the Nikki does not like. I even tried to dilute the older fuel to no avail, and finally got tired of emptying the under-seat tank to put only fresh fuel in. Learned my lesson. I figure the Federal standards pushed for the more sophisticated {Read: expensive} Nikki to be specified in the 5 year newer model, so it has smaller, more precise metering that stumbles when water content {a guess} is a bit higher than normal. The tank had a lot of water in it when I got it home, and the fuel I put in had been in the gas can for a couple months. Sealed tight, but older. The fuel cutoff solenoid was gummed {replacement ~$80 !!!} and I had to remove & clean it several times before it ran well.
In retrospect, maybe I should have considered looking to see if there was a Walbro replacement specified. Might have been less expensive. I sure got good at removing the cutoff and dropping the float bowl. Next thing to go was the fuel pump. No kit available, just new replacement. Cost more than ANY auto fuel pump I've ever purchased except electric.
tom
