1 - 3 of 3 Posts
What cross reference can you suggest for these bearings?
Mower gearbox
1185 431 thrust bearing (2 needed)
1713 665 needle bearing (3 needed)
There should be a number on the bearing itself, not the parts book number. That number will be an industry standard that can be used to xref any maker.
Discussion Starter #3 (Edited)
Unfortunately the number on the bearing is not visible.
I think I found it through google. This page x-refs all the mower deck bearings, belts, and seals:
Bolens G Series
description Bolens pt # Trade pt # Quantity
shaft seals 1185296 NL- 470954 2
needle bearing 1185010 SCE -1212 3
thrust bearing 1185431 TC - 1220 2
thrust washers 1185432 TWA(B*) - 1220 4 (4)
closed end needle bearing 1713665 BCE - 1212 1
so I search Amazon and find
Torrington B-1212 Drawn Cup Needle Roller Bearing
Frequently Bought Together
Torrington NTA-1220 Needle Thrust Bearing Cage And Roller Assembly
Duh. I can take a hint delivered with a 2x4.
1 - 3 of 3 Posts
