I have a Craftsman riding mower with a 19 hp briggs and stratton model 407777-0124-e1. It is about 10-12 years old and I'm the second owner. The problem is the mower will run, but only at half choke. Even at half choke it sounds like it's about to die, and if I go through any grass high enough with the blades engaged it will die. Any ideas?
I realize this could be a multitude of problems associated with the fuel system. I've checked the fuel filter and it is filled with fuel and looks clean. I had the entire fuel system ripped apart by a friend that is mechanically inclined and he cleaned everything, replaced spark plug, cleaned air breather. I have read it could be the exhaust. When I first start the mower after it sits for a while it smokes a bit like it's burning oil. I checked the oil and it was about a half quart low, and there's some oil spatter under the engine block.
Is there some easy to check stuff that I could do myself that doesn't require a great deal of knowledge / experience to perform? I'm not a mechanic, but I'm not a dummy. I can follow instructions and I'm eager to learn. What are the top 5 things you would check first with these symptoms?
