Video Review Version...
Click here to see Video
Written Review Version...
I'm sure everybody has used a wheel barrel before and they are handy to have but they do have their limmitations. They are not able to haul loads above 300 pounds because they ride on one tire. The other limmitation is yourself, just how much weight do you think you can push for a certain distance? And how much weight do you think you will be able to push up a hill? Wheel barrels are great for small jobs but just don't make sence for the larger projects.
This is a Craftsman/Husqvarna 12.5 CU. FT. Dump Cart. It runs on a 1" axle with 16" tires. It has a load capacity of 12.5 CU. FT. heaping amount and a weight capacity of 750 pounds. Because this is a polly cart, they are able to mold it so there is slots to convert it into smaller compartments if you want to keep two items seperate. This design also allows it to be rust free, cause its plastic not metal.
I recently used this cart to haul at least 1200 pounds worth of gravel in two loads of course. Since gravel weighs a lot, I did not want to overload the cart so I did not fill it up heaping but I have to say I am impressed as the axle never bent and nor did the tires deflate. In other words, I truly believe this cart can be loaded to its rated weight capacity of any type of material.
I have also used this cart to haul away yard waste, if you liked your wheel barrel before for that sort of thing, your really going to like this! It holds so much more then your wheel barrel and can reduce your amount of trips to your compost pile by 50%. And because of its dump mechanism, weather yard waste or other material, makes unloading a breese.
The only bad thing I can say about it is if you have a bagger system installed on your tractor, the cart may not clear the bagger framework. And even if it does, such as my tractor, you can't dump from the tractor because part of the cart is bellow the bagger's framework, which means you would have to unhitch to operate the dump mechanism. Craftsman can solve this problem by having a longer drawbar.
This cart currently can be bought from Sears for $170.00 bucks and I give this a 4 out of 5
