For the test light checks, leave the engine OFF.
Just the key ON.
You can have the key OFF while you swap OPR's around.
Look for one or more that lights up noticeably brighter than the others.
All 3 installed should be brightest.
Removing any one should reduce brightness.
Removing any two should reduce brightness more.
All 3 should reduce brightness the most.
The fuel solenoid should draw a similar amount of current.
With the fuel solenoid and all 3 OPR's disconnected, the light should be out, since no current should be flowing.
Remember, you have to "manipulate" the seat switch (occupied) to "turn them ON".
Look at the schematic.
Current flows from A1 on the key switch, through the seat switch to the OPR's.
Just the key ON.
