Hi All,
With the TT K46 being so expensive to replace or repair I was wondering if anyone had converted a Hydrodrive to a manual box?
Are the manual boxes tougher than the Hydro's?... any other disadvantages?
All the best.
Neo
I do not see the cost savings because you are going to have to figure out the shift linkage so I think a new fender/seat pan would be in order unless you are just going to cut a hole in the one you have. I am not sure it would be worth the hassle. You would be better off finding a stronger hydro if you have to replace it.
a hydro is so much better is almost every situation.
if I thought mine was weak I would still stick with it and fix/replace if an when it failed!
could not imagine going back to a manual tranny!
