Converting 45 Loader to JDQA - Build
15830 Views 35 Replies 15 Participants Last post by  X748SE
24
MTF user badgerland01 brought up this subject recently about anybody doing this and I’ve been mulling about doing this for quite a while so I thought I was about time I did it.
I wanted to model my JDQA after the JDQA that is used on the H120 loader on the 1023/1025.
Green Leaf Plant Vehicle Grass
So this is my version of what I did to make my 45 loader to have a quick attachment mechanism in order to quickly exchange the bucket to a set of forks, which BTW are yet to be built.
Since pictures seem to tell a better story this thread will be picture heavy.
Started off by ensuring that I could get the 3/4” round bar, which JD refers to the loader “equalizer link pin” drilled out correctly for the pin fasteners.
Green Vehicle Grass Lawn Mower
Used a 4 ¼” grinder with a very thin cutoff blade and first remove the bottom 1” square hydraulic cylinder over extension stops.
Machine Angle grinder Pipe Machine tool Tool
Green Machine Machine tool
Then used the cutoff grinder to carefully cut out the existing welds on the bucket brackets. Used a large adjustable wrench to wiggle the bracket side back and forth the snap off the rest of the weld that I couldn't get with the grinder.
Tool
Green Machine
Green
Note: A 5” grinder with a thin cutoff blade would work better than the 4 ½” one I used.
Marked out the cut lines and using a hole saw, drilled the holes for the top 1 ¼” bar.
Green Machine Vehicle
This pictures show the pieces that will be used on the loader side. In the end I didn’t use the two small rectangular supports as I felt I didn’t need them after thing were welded up.
Green
Chamfered the holes on the back plate so that the locator pins would slide in easier.
Circle Games Metal
Picture showing the bucket side attachment brackets and pins. The curved formed ones were bought from JD.
Metal
Picture showing bucket bottom plates and pins with chamfered edge.
Circle Metal
Pin ready to be welded in. Both plate and pin have chamfered edges in order to get a deeper penetration weld.
Steel Metal
This is the set up that I use to get everything aligned before I tacked the side plates on. I used exact width spacers between the sides to keep them properly spaced.
Machine Auto part Metal Pipe
Used a 1 ¼” round bar to align the top “fittings” of the JDQA and then clamped an angle iron next to it in order to have a reference line.
Machine tool Metal
Removed the 1 ¼” round bar and tacked in the “real” cut to length top fittings and started to weld the loader side brackets.
Machine Vehicle
Installed the brackets on the loader arms and then extended the cylinders to the point just before they started to bend. Clamped, tacked and then welded on the 1” square bars to serve as over extension limiters.
THANKS bagerland01 and AndrewOliver for the info on this!
Land vehicle Vehicle Motor vehicle Grass Lawn
Vehicle Motor vehicle Bumper Automotive tire Tire
Got the bucket lined up and welded on the bucket-side brackets.
Machine
Green
Tested it out on the dirt pile to verify if the brackets would hold up to riggers of loader work, thus things got a little dusty and dirty. So this is how my version of the JDQA looks on the loader.
Green Vehicle
Green Machine Vehicle Plant
Green Machine Vehicle Metal
Now comes some touch up and green paint.
Roger
1 - 20 of 36 Posts
Couple more pics.
Vehicle Grass Lawn Bumper Machine
Vehicle Automotive exterior
Roger
Looks great Roger. Nice work. Thanks for sharing. :thThumbsU
Awesome work Roger. Looking at the setup, you had to pretty much fabricate everything except the u-shaped pin mount?
Very very nice, as always. :thThumbsU
Yours looks a lot prettier than mine. Did you cut out pieces with a plasma cutter? It looks like a factory made Q.A. I got mine functional, and never got around to the cleanup and paint phase. I like your upper bucket mounts better than mine. The upper mounts on my forks got bent out by the force of the curl cylinders picking up heavy loads with the tips of the forks. I like that yours have side plates to strengthen them. Are the 2 sides of the tractor side mounts hooked together by that pipe so that they both move at the same speed? We have a big Deere (5420) that they aren't, and it can be a real pain sometimes.
Great write up and great job Roger. Your QA looks great
You did an excellent job on the work and the write up. We'll done as always sir.:congrats:
Nice work Roger!! This inspires me to attempt this project.... Once I have the metal working part down! :D
Well done, Roger! Inspiring and classic craftsmanship on display, again. Jay
Larry,
Thanks! I hope to get it painted by the end of this weekend as I need to do some loader work. It will be a good test for it.
Roger
Bill,
Thanks! I fabricated everything except the bucket side "receiver" brackets which I bought from JD. The U-shaped pin brackets are made from 1 1/4" round bar which were drilled out and welded on two sides only. I then took my grinder with a thin cut off blade and carefully cut out the slot where the pin goes. It definitely took a bit of time to do this.
Roger
Andrew,
Thanks! Well to be honest it was one of your posts that you made in badgerlands01 thread about bending your upper mounts when using your forks that made me think about my original design (which was totally different then what I built) and that I needed to changed it somehow to prevent this.
In order to do this I realized that I needed some sort of reinforcement on the sides of the upper receiver bracket. What this entailed was to change the design so that the loader brackets were a little narrower so that the "stub" could fit up inside. Everything after that sort of fell into place.
I only used the plasma cutter to "rough cut" the piece out of the loader front brackets. I "straightened" the cut by clamping the two pieces together along with a piece of angle iron. I then used my grinder to grind down the edge until it reached the angle iron. The metal was cut to length using a metal chop saw and all holes where drilled on the drill press using metal hole saws.
The 3/4" bar that is between the loader bracket does keep the brackets aligned. I basically copied what JD did with their H120 loader.
Roger
Very nice!! :fing32:
Mike X485,
THANKS!
Roger
Deerx585,
Thanks and the intent on the write-up was to help anyone considering doing this type of mod.
Roger
badgerland01,
Thanks! It gives you something to think about when you get around doing yours. There are few things that I would change and one of them is the use of pins. It was a bit late for me to change the design as I already had them (pins) made and it was a lot of work getting everything aligned. I really like the way AndrewOlivers latch works on his QA.
Roger
Kyle,
Thanks!!
What do you mean "attempt" ... As Yoda said: No, Try not, Do or do not, there is no try!
It really wasn't that hard to do. I think the hardest part for me was taking the grinder and making that first cut on the bucket brackets.
Roger
Jay,
Thanks, Still learning about that craftsmanship you speak of. I sometimes feel I'm $%^& lucky to have things turn out they way they do. What people don't see is how many times I have to remake a part or fix it somehow.
Don't tell anybody but I made 2 "lefts" of the lower bracket that are on the bucket. I welded the pins in and found my mistake, drilled one of the pins out, re-welded the pin in again only to find out that I made 2 "lefts" again. Cursed a few times and called myself an idiot. At that point I called it a day....
Roger
Nice Job!
tractorPete,
THANKS!
Roger
I can only think of one word. WOW.:fing32:
Hey Roger.....what size pins did you end up welding on the bucket? Did you make them or buy them?
Eddie,
Thanks!
Roger
badgerland01,
I used 7/8" cold rolled bar and I made them. I priced out the ones JD makes and they were just too expensive.
Roger
Finally got some paint splashed on it.
Roger
That looks excellent Roger. Are the holes in the loader side for weight reduction, or do they have a purpose?
Another fine job Roger.
Great job Roger! On both the QA and the write up! It would have been nice to have this when I was building all my stuff, mine is definitely heavier than the the one you built weight wise . Yours turned out really nice, maybe someday I'll rebuild mine but it will be a while
Roger,
Superb work. I know what you mean about making the first cut...
Now, take that 4-1/2" angle grinder & thin-kerf cutoff blade to those goal posts. :)
Andreas
1 - 20 of 36 Posts
