1 - 8 of 8 Posts
I have an extra 400 3 point thinking about cutting the lift brackets off of the 400 rock shaft and mounting them to the 318 rock shaft .
I have debated welding them or making a bracket to clamp them to the rock shaft even considerd just making new lift brackets so I wouldn't cut up the 400 rock shaft.
I will also have to make the brackets that bolt to the axel for the lower arms
Any sugestions I can do it either way just wanted to see how others may do it someone may have a better plan.
Discussion Starter · #3 · (Edited)
Everything is correct except the rock shaft that deere wants $450 for and $40 each for the two lower brackets. And I have not found the rock shaft for it on the net looked on ebay complete 3 points about $350 a bit more than I want to spend I have considerd that or would trade Rock shaft if someone had one to trade.
You will get about $250-300 for a complete 3 pt hitch for a 400 on Ebay depending if it is complete and functional. There was a brand new NOS one that went for $325+/- last week.
If you sell it as opposed to cutting it up then you won't have to put out that much money to have the correct 3 pt hitch for 318. You will also have made a 400 owner happy...
Ok I have ruled out cutting up the rock shaft I have a Lead on a 318 3 point if it works out the one for the 400 may be up for gabs
The Magnificent
That's pretty decent of you - some of this stuff is getting hard to find and original OEM parts are important to many.
Your pups don't exactly look thrilled to be there.
Discussion Starter · #8 ·
They love the water and riding in the paddel boat and floating on the raft that pic did not do them any justice.
1 - 8 of 8 Posts
