First time poster here.. I'll try to keep this brief and to the point..
I am looking into a Kubota for the first time, possibly a BX1860 or BX2350 or BX2360... Price is a concern, as it normally is.
I am considering a purchase brand new (Unless someone is selflessly trying to sell their relatively modern model!?!), and am considering the FEL, but probably no mower, as I will use a PTO finish mower later on.
WHAT ARE YOU USING THIS FOR!?!
We own over 5 acres, will probably brush hog about 2+ acres, and finish mow the front 2+ acres. The land is all hills, and definitely needs some raking/grading/smoothing, as well as removal of a ton of rocks/stone from when the house was finished built in October, as well as the septic tiles.
QUALITY OF WORK!?
This is way out in the country, and we do not plan to 'seed' the yard that would make Bob Villa proud, we will try to keep the grass and weeds cut neat, and maybe over time overseed in an attempt to kill off some weeds...
The front of the yard has a lot of old rickity trees, and fence posts with barbed wire from when this was a field, so the FEL should come in handy if I choose to buy it for that purpose.
We are in Ohio, and have about a 400ft driveway that I used a snowblower on an old tractor last year (first winter here) worked fine on the gravel drive, but if I got a FEL, I'd plan to sell this old tractor and only have one main tractor.. so either look at a snowblower or blade to put on the FEL (so as to not fill up the bucket constantly while plowing in the wet thick ohio snow).
That is the jist of it, ask questions away, I've hunted through craigslist a ton, and found many for the $7000+ range, which makes me say "let's just buy new".. but under that range I think I'd be very curious to buy used. Added to that I definitely want 4wd for these uses, and plan to have R4s on it all around...
Please help, ask questions, suggestions, etc. as I first started this tractor search looking at ford 8n's... and here I am now looking at a Kubota 5x more expensive (oy vey)
QUALITY OF WORK!?
