The 'Shoulder' is worn off of the spindle right below the 'Hex'.
They do wear down, usually from a loose blade.
He will need to replace the blade spindle shaft. They are a common wear item, along with the spindle bearings.
They are not expensive for the parts to rebuild the spindle. Most times you can get the entire spindle assembly. They are a little bit more expensive, but then everything is new, shaft, bearings, housings.
They are the wrong blades on it now. The center hole is way to big. Simplicity uses a much smaller center hole on that model deck.
Usually you have to get the blades from a Simplicity dealer. Some decks use 2 different size blades on the same deck. Some decks use 'Low Lift' mulching blades, some use 'High Lift' bagging blades, some use General Purpose blades. They did make optional blades for most of their mower decks besides the standard blades.
