1 - 6 of 6 Posts
im taking apart my engine and got stuck. Kohler k241 (10hp case motor)
how do I take out the connecting rod! I took the 2 nuts off and tryed lifting the cap (with the dipper rod) off but it aint budging. the engine didnt blow up or anything prior to disassembly.
if someone can tell me if their is anything im missing?
take a soft rubber mallet or a glass hammer and a small peace of 2x2 ..Place the 2x2 on the rod and tap it it will brake free ..Dont use a screw driver
the rod has studs that go thru the cap where the nuts went on.
the nuts are off but he studs are still sticking up, are they supposto push down and out?
they should stay in the rod you can place the 2x2 or a peace of wood on the studs and tap them easy that will brake them free also ..some times the studs will pop out if you hit them to hard but you can put them back in not a big deal ...Just tap them easy with a block of wood and a hammer...I always have a peace of 2x2 or a 2x4 that i cut in half for doing this
1 - 6 of 6 Posts
