Here are some questions I hear all the time..online, in person, over the phone...
My push mower rips the rope out of my hands when i pull it....
--Your flywheel key is sheared, replace it, and check the blade.
My briggs starter is turning backwards, it sucks the gear down??
--Your battery is hooked up backwards
My Briggs OHV,Kohler Courage, Tecumseh OHV engine turns over hard, like it has a weak battery, but its not the battery...engine is over a year old.
--Your valve lash needs to be reset to activate the compression release.
Mower wont turnover, none of the lights work, its all dead..battery is good.
-- Most likely cause of sudden loss of everything is a blown fuse.
My generator runs wide open as soon as it cranks...
-- Usually a generator sits for a while and varnish builds up on the throttle shaft, and it stocks, ensure the throttle moves from idle to full throttle smoothly.
My engine was working fine, now runs full tilt.
--Assuming the governor gear isnt broken, and nothing has jammed the linkages up...the most common cause us a slipped governor lever. Simply find the governor shaft and lever, loosen the pinch bolt. move the lever from idle to full throttle and note shich direction that motion turns the governor shaft in the block. Now hold the governor arm full throttle, and using a pliers, turn the shaft in the direction of full throttle until it stops. without moving anything, tighten the pinch bolt.
My Kohler Command is noisy, alot of mechanical chatter.
--Change oil, add 10w30, run for 20 minutes at full throttle..if that does not fix it, add an ounce of sea foam to the oil, run full throttle for 10-15 minutes, change oil, add clean and fresh 10w30....this will get the lifters pumped back up 90% of the time. If they are still clacking...they may be defective or damaged.
Ill add more later...
