I have been running a 40" comm mowing deck on my L8 since the beginning of the cutting season, and I have been pretty pleased with it. Initially I had some issues with a gear noise that stopped when I tightened up on the mower neck to allow it to level with the ground, it was really loose. I have greased all the fittings, sharpened and balanced the blades, checked the belts and topped off the gear box with fresh gear oil, typical maintenance.
Like I said, I am pretty pleased with the cut, but how can I improve it? I only have one baffle on the left side, would it be worth it to bend up some baffles? What about blades? I have been doing some searching and can find stock replacement blades, but what about hi lift or a gator style blade.
I mow with the axle in low, and PTO in high so my ground speed is nice. Any suggestions?
