Thanks guys.
It's been about 8 years since the last time I left a tractor outside in winter for this reason. That was with the 2003 DLT3000 (25HP Briggs Intek twin). I was able to get it started with carb cleaner (or starting fluid), but it wouldn't stay running, which is what made me think there was an issue with the gas being left out in the cold. My detached garage was neither heated nor insulated, but when I left the tractor in there, it would always start.
OK, we're in a different house now, and new (used) tractor. This garage is attached, but is also neither heated nor insulated. We had the same old tractor up until last year when I caught it on fire while chopping up leaves (long story), so I bought the used 2003 GT5000 (25HP Kohler twin). Never had any trouble starting it in the garage last winter.
This year, we haven't had snow yet, so I have been very slow to get the garage cleaned out to make space for the tractor. I did try to start it yesterday (18 F outside), and now all I get is a loud click, and the engine isn't turning. I'm assuming it's the battery, but I certainly don't know if I'm having the same gas issue. I do have 5W-30 oil in there.
The choke/carb is another issue. The engine hasn't been running right since last year when I ran out of gas once. Must have picked something up that got by the brand new filter, and clogged the carb, because it will only run on partial choke (after starting). Towards the end of the fall, it also is acting like it's not getting gas when going up hills. Not sure if that means the gas pump is on its way out?
I always start it with full choke. And, the choke cable likes to freeze in place, even in the summer time. I've tried lubing all the obvious points, must be missing something.
So, I need to finish cleaning the garage, strip the carb and replace the battery.
OR... just find a used GT5000 with a manual tranny so I can swap over my 46-inch snowblower and be done with this thing...
Mike
