Ok, well now that I have gotten my lil tractor running, the only issue I have found is that when it is in gear the brakes don't seem to work. When it is off and in neutral and you press the brake/clutch it stops the machine to the point it will drag the rear tires, but when it is running you can't hold the machine from moving. So knowing this I think that the clutch is not disengaging the engine from the transaxle. Also when it is moving along you can't shift the transaxle from F-N-R with the clutch pressed because it wont stop moving in the gear that it is in.
This is the tractor
Discussion Starter · #2 ·
OK guys, well I guess not only is the clutch non functional but it seems like it only has first gear, after that the only thing that moves is the shifter lever (1-7 speed). So is it like a siezed up lever or pully?
It has varidrive system . remove fnr shift cover . belt from engine to varidrive pulley then belt from there to transaxle . Check that brake is loosening front belt .check for belt guides at engine pulley .there is also an adjustment procedure to follow after changing belts
Welcome to the forum COL. You should have a nice rider when you work though these issues.
