Can I pull off the clutch hub (the inner clutch part that spins)? Do I need some kind of puller to get the oil seal out first and will the hub slide out then?
I undid the snap ring but there seems to be another step or tool needed.
On my forward clutch there is a lip around the lower face of this that I'd like to file down so the whole face is flat again. Would be humongously easier if I had that hub clamped in a vise don't you know.
thanks
thanks
