Reviving an old topic... I prefer that to starting a new one.
My PK 1614 broke a shift fork in the tranny, probably due to my father-in-law long time use of the PK with a clutch problem... lots of raking, grinding, etc. The clutch pedal never did move much at all when I occasionally used it. I had a bit of an
issue separating the tranny from the engine, but that got resolved with help from the fine folks here.
Now that I have it all apart... the throwout arm or Y-shaped piece that contacts the ears on the throwout bearing has significant wear on the tips - I am guessing that is why the clutch pedal no longer seemed to have much effect. The wear on the throwout bearing ears isn't too bad (yeah, I need to try to measure it).
So, what are my options? Replacement of the throwout arm, P/N 03-7501?
Thanks,
W-E
