Note: That brake arm must have the section that is bent into a vee shape, mounted so the pointed part points toward the back wheel. When you step on the brake pedal, when the brake arm turns, the raised pointed brake arm will push in the two little pins, and they then push in the brake pad, to contact the disc brake. There should be a thin metal piece, same size as the brake pad, to keep the little pins from breaking the brake pad. It goes between the pad and the housing. Keep the brake assembly well lubricated.
