1 - 3 of 3 Posts
Sears Aficionado
Hi all! Before I ran off to the store I thought I'd ask around to see if anyone knew off hand what size Clevis Pins are used for the bottom set of (Strap Holes) on the front of the ST/12. I'm reattaching an old Dozer Blade (917253330)
:trink39:
7000 posts and climbing!
I don't know but the part is still available if you are willing to buy them.
http://www.jackssmallengines.com/Parts-Lookup/8940h/126439/pd
My guess is you might be able to use an adjustable length 5/8" diameter clevis pin in the lower holes on the front axle.
Otherwise you might be able to use the following but I do not know the width of the brackets they have to pass through.
http://www.fastenal.com/web/products/fasteners/pins/clevis-pins/_/Navigation?term=&termca=&termpx=&sortby=webrank&sortdir=descending&searchmode=productSearch&rfqXref=&rfqKeyword=&rfqId=&rfqLineId=&r=~|categoryl1:"600000 Fasteners"|~ ~|categoryl2:"600108 Pins"|~ ~|categoryl3:"600109 Clevis Pins"|~ ~|attrdiameter:790|~ ~|attrlength:1450|~ ~|sattr05:^Steel$|~
1 - 3 of 3 Posts
