1 - 3 of 3 Posts
What type wrench does one use to get the ck level transmission plugs out? My 2414 has the cover over the trans's and drive tube. I used to have some 8 point sockets, but in moving, I'm not sure where they are.
Thanks for any help.
Discussion Starter · #2 ·
For all those that might not have known, a 8 pt 9/16" socket will reach & remove the transmission fill plugs thru the driveshaft cover.
i couldnt remember what i used on mine thats why i didnt answer, but i knew you would get it.dont over fill, if its filled to fill hole its over full and can blow seals, little finger in hole should just touch oil.i put stp, in mine and the grinding that is common with pks, is almost gone.i do not shift on the go im at dead stop.
1 - 3 of 3 Posts
