1 - 16 of 16 Posts
My knees are getting bad.
· Super Moderator
nice--give us some details!! and details......
· Deere 330 Killer
nice! i need to get me one of those!
· Young Buck
I need a four post that size, so i can stack, save space in my shed, and work standing up.
It is a motorcycle lift with side extensions, 84 inches long and 53 inches wide. lift capacity is 1500 lbs to a height of about 40 inches. All the way down height is 7". I did not get the vice for the bike wheel but as you can see it has a drop out section in the rear for take the wheel off. It also has a front extension for bikes making it 97" long total. operates on 90-100 PSI air. The whole best thing about it is its made in the USA. Iowa to be exact, and used on USA made tractors.
That is a nice little setup need to get one myself.:fing32:
· Eleven Year Site Sponsor
Discussion Starter · #12 · (Edited)
Those of you who think you want one go to www.Mile-X .com
· Super Moderator
after you use it awhile--post back with a review--give us the exact working height , off the floor, also--they say only 30 in.-
-unless I looked at wrong model number....
and thanks--
glenn
Discussion Starter · #15 ·
You need to be on model# 14472. I was going to get one from a company in Calif until I rerd a reveiw on it. Where the guy said he had to weld on it for 4 hours just to be safe using it. So thru my sufing I found Mile-X.I will modifie it just a bit with locking steel casters at the ramp end to make it esier to move when the need arises.
1 - 16 of 16 Posts
