1 - 1 of 1 Posts
Precision Application
SHURflo 12VDC Ag Runner Inline Portable Chemical Transfer Pump (SF-1100-PTSI)
ShurFlo 12VDC Ag Runner Portable Frame Chemical Pump (SF-1100-PTS)
The Shurflo Ag Runner allows you to automatically pump and measure chemical from the chemical container directly into the sprayer tank without the need for manually measuring or any other handling of the chemicals.
• Max Output: 40 L/min open flow
• Max Pressure: 15psi
• 12 volt operation with 6m lead & alligator clips
• 1” x 3.6m suction / 1” x 3.6m delivery hoses
Shurflo pumps are engineered to pump thin or thick ag chemicals. 10 GPM with water; 7 GPM on ag chemicals at 70 Deg. F. or 4.5 GPM on cold or viscous liquids (860 CPS). Glass-filled polypropylene body with unique design bonds the polypropylene pistons to the santoprene diaphragm (co-molded). Oversized 3" magnet motor. Can be serviced with hand tools only.
ShurFlo 12VDC Bulk Chemical Transfer Pump (SF-1100)
Engineered to pump thin or thick ag chemicals. 10 GPM with water; 7 GPM on ag chemicals at 70 Deg. F. or 4.5 GPM on cold or viscous liquids (860 CPS). Glass-filled polypropylene body with unique design bonds the polypropylene pistons to the santoprene diaphragm (co-molded). Oversized 3" magnet motor. Can be serviced with hand tools only.
Model SF1100 has 2" MPT inlet (pump only, less adapter, suction tube, hose & nozzle valve)
1 - 1 of 1 Posts
