I've seen chains that were sharpened by a shop,and the cut area was done with a smaller stone.Myself,I'd look for the correct size,maybe online.The larger size would grind away the top before it gets into the kerf of the chain.:trink40:Once done,if you'll touch it up more offen,you wouldn't need the dremel.But I use one as well,so who am I to suggest that!!:sidelaugh
