I have all of the problems starting this as everyone else and am doing the recommended fixes of making sure starter gets full voltage. My problem;
How do I wire in a manual glow plug button/switch and by pass the existing glow plug timer and glow plug relay? I also would like to wire in a starter button.
For a manual glow plug you just need a momentary push button and a continuous duty rely. Probably should at least 12 ga wire for the glow plugs from the relay.
Use the same for the starter only you don't need a relay, just find the key start wire on the starter solenoid and run it to the starter button and then to the starter solenoid.
mmcwill1156, Did you ever get the problem fixed? Like bypassing the factory glow plug starting system to a manual setup. If, let me know how to did all this, as I need to do the same on my 2005 #6284.
Thanks,
Fred
Related Threads
My Tractor Forum
4.3M posts
216.7K members
Since 2005
