1 - 1 of 1 Posts
TYPE CODE ERROR
ENG 111 Engine Controller Failure - Hardware Failure
ENG 115 Engine Speed Sensor (8.3, 9 Liter) or Cam Sensor (15 Liter) is failed
ENG 121 Engine Position Sensor (8.3, 9 Liter) or Crankshaft Sensor (15 Liter) is failed
ENG 122 Boost Pressure Sensor voltage is too high
ENG 123 Boost Pressure Sensor voltage is too low
ENG 124 Boost Pressure level has exceeded the warning limit.
ENG 131 Decelerator or Hand Throttle (STD cab) Position potentiometer voltage is too high
ENG 132 Decelerator or Hand Throttle (STD cab) Position potentiometer voltage is too low
ENG 133 Decelerator (STD cab) Position potentiometer voltage is too high
ENG 134 Decelerator (STD cab) Position potentiometer voltage is too low
ENG 135 Oil Pressure Sensor voltage is too high
ENG 141 Oil Pressure Sensor voltage is too low
ENG 143 Oil Pressure level has fallen below the warning limit.
ENG 144 Coolant Temperature Sensor voltage is too high
ENG 145 Coolant Temperature Sensor voltage is too low
ENG 146 Coolant Temperature level has exceeded the warning limit.
ENG 147 Frequency Throttle Signal shorted high
ENG 148 Frequency Throttle Signal shorted low
ENG 151 Coolant Temperature level has exceeded the warning limit.
ENG 153 Intake Manifold Temperature Sensor voltage is too high
ENG 154 Intake Manifold Temperature Sensor voltage is too low
ENG 155 Intake Manifold Temperature level has exceeded the warning limit.
ENG 187 Sensor Supply 2 Voltage is too low.
ENG 191 A/C clutch driver shorted to ground when ON.
ENG 211 Communications problem with Armrest, Instrumentation, or Transmission Controllers
ENG 212 Oil Temperature Sensor Voltage is too high
ENG 213 Oil Temperature Sensor Voltage is too low
ENG 214 Oil Temperature Sensor Voltage is above normal range
ENG 219 Oil Level - remote reservoir is too low. Add oil.
ENG 221 Ambient Air Pressure Sensor Voltage is too high
ENG 222 Ambient Air Pressure Sensor Voltage is too low
ENG 223 CORS - Burn Valve Solenoid is shorted either low or high
ENG 227 Sensor Supply 2 Voltage is too high.
ENG 234 Engine Speed has exceed the overspeed warning limit.
ENG 235 Engine Coolant Level is low. Add coolant fluid.
ENG 237 External Speed Multi Unit Sync Command Input Data Incorrect.
ENG 241 Vehicle Speed Signal lost
ENG 242 Vehicle Speed Signal intermittent / tampering
ENG 243 Error detected in exhaust brake relay
ENG 245 Fan Clutch Voltage too low
ENG 254 Fuel Shutoff Valve Voltage too low
ENG 255 Fuel Shutoff Valve Voltage too high
ENG 259 Fuel Shutoff Valve mechanically stuck open.
ENG 263 Fuel Temperature Sensor voltage is too high
ENG 265 Fuel Temperature Sensor voltage is too low
ENG 268 Fuel Pressure in pump is not changing with operating conditions.
ENG 271 Front Pumping Control Valve current is low during ñclick testî
ENG 272 Front Pumping Control Valve current is high
ENG 273 Rear Pumping Control Valve current is low during ñclick testî
ENG 274 Rear Pumping Control Valve current is high
ENG 275 Front Pumping element is failed
ENG 276 Injection Control Valve current is out of range
ENG 277 Injection Control Valve is failed
ENG 278 Fuel Lift Pump is failed
ENG 279 Injection Control Valve current is out of range
ENG 281 Front Pumping element is failed
ENG 282 Rear Pumping element is failed
ENG 283 Engine Speed/Position Sensor supply voltage is too high
ENG 284 Engine Speed/Position Sensor supply voltage is too low
ENG 285 J1939 Parameter was set to be multiplexed, but not received (timeout error)
ENG 286 J1939 Parameter was set to be multiplexed, but not available from all sources (config error)
ENG 287 Multiplexing throttle parameter and a data error was received - data invalid
ENG 288 Multiplexing remote throttle parameter and a data error was received - data invalid
ENG 293 Hydraulic Fan Hydraulic Oil Temperature Sensor Voltage is too high
ENG 294 Hydraulic Fan Hydraulic Oil Temperature Sensor Voltage is too low
ENG 295 Ambient Air Pressure data invalid
ENG 297 OEM Pressure Sensor Voltage is too high.
ENG 298 OEM Pressure Sensor Voltage is too low.
ENG 299 Engine Shutdown by other than keyswitch (i.e. via data bus command)
ENG 319 Real Time Clock in controller has lost power
ENG 328 Rear Pumping element is failed
ENG 329 CAPS Pump has an overpumping failure
ENG 338 Idle Shutdown Vehicle Accessory Relay Voltage is too high
ENG 339 Idle Shutdown Vehicle Accessory Relay Voltage is too low
ENG 341 All data written during powerdown cycle was lost (checksum error)
ENG 343 Engine Controller Failure - Hardware Failure
ENG 349 Measured Speed is too high.
ENG 352 5 Volt Sensor Supply voltage is too low
ENG 378 Front Fueling current is too low
ENG 379 Front fueling current is too high
ENG 381 Error detected in cold start relay 1
ENG 382 Error detected in cold start relay 2
ENG 385 5 Volt Sensor Supply voltage is too high
ENG 386 5 Volt Sensor Supply voltage is too high
ENG 387 Decelerator or Hand Throttle (STD cab) 5 Volt Supply voltage is too high
ENG 388 Engine Brake driver 1 circuit failure
ENG 392 Engine Brake driver 2 circuit failure
ENG 393 Engine Brake driver 3 circuit failure
ENG 394 Front Timing current is too low.
ENG 395 Front Timing current is too high.
ENG 396 Rear Fueling current is too low
ENG 397 Rear Fueling current is too high
ENG 398 Rear Timing current is too low
ENG 399 Rear Timing current is too high
ENG 412 J1708 data link cannot transmit
ENG 414 J1708 data link not fast enough
ENG 415 Oil Pressure level has fallen below the very low warning limit.
ENG 418 Water in Fuel sensor indicates the water in the fuel filter needs to be drained.
ENG 419 Boost Pressure data invalid
ENG 422 Engine Coolant Level Sensor (optional) is failed or the jumper plug is missing
ENG 426 J1939 data link cannot transmit
ENG 427 J1939 data link not fast enough
ENG 428 Water in Fuel Sensor voltage is too high.
ENG 429 Water in Fuel Sensor voltage is too low.
ENG 431 Hand Throttle (STD cab) Idle Validation Switches are both closed
ENG 432 Hand Throttle (STD cab) position potentiometer and switches disagree.
ENG 433 Boost Pressure level disagrees with engine operation conditions (speed & power)
ENG 434 Unswitched 12 volt supply voltage disconnected without normal key off sequence.
ENG 435 Oil Pressure data invalid
ENG 441 Battery Voltage is too Low (less than 6 volts)
ENG 442 Battery Voltage is too High
ENG 443 Decelerator or Hand Throttle (STD cab) 5 Volt Supply voltage is too low
ENG 444 Low voltage detected at OEM 5 volt supply
ENG 449 Fuel Pressure level has exceeded the warning limit.
ENG 451 Fuel Pressure Sensor voltage is too high
ENG 452 Fuel Pressure Sensor voltage is too low
ENG 456 Fuel Pressure in pump is not changing with operating conditions.
ENG 465 Wastegate 1 voltage is too high
ENG 466 Wastegate 1 voltage is too low
ENG 482 Fuel Pressure Sensor voltage low
ENG 483 Rear Bank Post Actuactor Pressure voltage high
ENG 484 Rear Bank Post Actuactor Pressure voltage low
ENG 485 Rear Fueling actuator overfueling
ENG 486 Rear Fueling actuator underfueling
ENG 488 Intake Manifold Temperature level has exceeded the warning limit.
ENG 489 Measured Speed Sensor data low
ENG 491 Wastegate 2 voltage is too high
ENG 492 Wastegate 2 voltage is too low
ENG 493 The Injection Control Identifier Circuit in the harness has failed.
ENG 496 Engine Speed / Position Sensor #2 supply is too low
Other CODES HERE IS
1 - 1 of 1 Posts
