1 - 9 of 9 Posts
So long story short I have a case Ingersoll 446 it was my grandfathers and I took the liberty of replacing the starter which was not fun at all. But for as long as I can remember this tractor hasn’t been charging itself when ever I want to use it I have to charge it. If I run it for awhile and shut it off then try turning it back on the amperes just says it’s dead. Do I need a new rectifier or is it something else??
If you're checking at the regulator, either the ground is bad, regulator case to tractor or the regulator is bad. If checking at the battery, it could be the ignition switch.
1 - 9 of 9 Posts
