1 - 1 of 1 Posts
Does anyone with experience using Case CNH Iron Gard paint have suggestions for mixing ratios for the paint as well as CNH gray primer.
Can label states 1 part thinner to 8 parts paint max. So, is the 8:1 usable or too thin?
I have been using thinner as the, well... thinner.
Never having painted with a HVLP before ( or anything other than rattle cans) I just don't know how thin it should be. I was once told it should take about 4 seconds for the thinned paint to drip off the mixing stick.
I will also be using the Case supplied Valspar hardener once it is in stock. (Thanks, everyone, for all the respiratory, eye, skin, etc. protection info.)
I have been practicing using the 8:1 ratio trying to set up my gun/comp. correctly.
( Eastwood Concourse 1.4 , 4.5 pk hp 21 gal 8.8 delivered at 40psi)
This is what I have been using for gun set up tips:http://www.stovebolt.com/techtips/hvlp_paintgun_basics.pdf
I'll ask gun set up questions on a later thread.
And Mark777...Thanks for paint tips.
1 - 1 of 1 Posts
