case 442
2614 Views 5 Replies 3 Participants Last post by  Dave true
I did some trading today and ended up with a 442 and mower deck iam not sure the year but it runs good and in good shape were snow blades common for these tractors and can you get a sleeve hitch for them this one does not have hydraulic lift it is manual thanks for any help Dave.
1 - 6 of 6 Posts
Yes, snow plow/utility blades and sleeve hitch are available.
Does your tractor have the quick attach front frame system? Or the older style.
Post a PIN / Serial number or pictures and we can help sort it down with you.
Brian
I got the serial number of my tractor thanks for the help the number is 9633710 Dave.
According to the chart, I would guess 1971. Pre-1972 units are not listed on the charts, but the serial # start of '72 is only slightly above your number.
Hydraulic lift was an option for the 442's in 1971. As far as a plow blade for it, if it has the large spring-loaded pins on the front of the frame rails, then that's the Snap-Fast mount system. A blade from practically any 400 series tractor will work, I believe. The lift lever set-up may be different due to the manual lift, I'll see if I can find that info.
Your tractor was not originally equipped with the snap-fast quick attach system and most probably is not now.
That limits the avialable implements ... but they are out there. Examples are F & G80/84 snowcaster. F50 & F54 utility blade.
Brian
Thanks for the info i will start hunting i would like to get blade for it Dave
1 - 6 of 6 Posts
