1 - 10 of 10 Posts
anyone have a wiring diagram with color code? or able to take pictures of their engine so I can trace the wiring on mine and fix it? PLEASE I am on my hands and knees!!!
wiring diagrams are available at ingersolltractorsinc.com. Use your sn to find the correct parts manual for your tractor, the wiring diagram is in the manual.
Landscaping Nut
Never seen a color code wiring diagram for case/ingersoll. All are b/w with no reference with wire color coding.
The wiring diagram in the owners manual has color codes. I expect to have one in the next couple of days and I will try to post it.
Bart,
That wiring diagram is in the mail, but I wonder if it would be the same on a JD? It would seem that "Ingersoll" would have "improved" it!??? LOL
I have the diagram, thanks to Rol, in pdf format and I will be happy to email it to anyone interested but it is too large to post here.
Re ingersoll backhoe
have a 6018 backhoe with a gear case problem. lost low range . need help locating a new gear case . also would like to find another backhoe thanks, skip6255
Re: Re ingersoll backhoe
200351196905 on ebay now!
Is your case busted? I think the gearing is the same on all Ingersoll tractors, though the case is HD for the 6000 series. A check of the parts catalog should give you the info you need.
http://ingersolltractors.com/index.html
1 - 10 of 10 Posts
